1.6 duratec problem
Hey. can anyone help me with my problem with a 2010 fiesta 1.6 tdi duratec 75 bhp model.
The car smokes ( black smoke ) badly under aceleration ( like i can easly see the smoke trail in the mirror ) , things i have done are :
1) changed intercooler was leeking oil
2) rebuild turbo
3) all fitlers oil change dissel filter
4) changed turbo actuator
5) changed the Boost controller
6) cleaned the egr
7) cleaned the throtle body
When i hook up the computer i get this 2 things
P132B-22 Turbocharger/supercharger boost control A perfomance a7
P132B-85 Turbocharger/supercharger boost control A perfomance af
and car goes in limp mode
Other things i notice first gear goes to 4k rpm second to 3.5 third to 3k and by the time im in 5 gear the car dosen;t go over 2.5k
Throtle body is wide open at idle
Car sometimes dies after not driving for 24 h , it starts perfect stays at 800 rpm no vibration or nothing then just dies instantly
Car stops smoking if i drive at constant speed for more then 30 sec
If any 1 have some ideas what can throw those 2 codes i would greatly appreciate it :D
Found this, both codes seem to relate to the same thing.
https://www.engine-codes.com/p132b_ford.html
i serched that and it said it was the 5) changed the Boost controller
only thing im not 100% the one that was on the car was like this
and i got something like this
and im not 100% i put it back in same order cause the one that was on the car didn't have any marks for what was each hole
any idea how to figure out wich goes where ?
The pipes are from the left, vent (to the small air filter on the end of a pipe at the back of the engine bay, just under the wipers), vacuum out to the turbo actuator and vacuum in from the vacuum pump.
Sometime the Vent pipe may go to the inlet duct just after the airbox.
This is from (with photo):
If that does not cure the problem, try disconnecting the MAF. This will cause a MAF DTC, but sometimes, if the MAF is faulty or fouled, it will run better without it. The MAF measures the airflow, so can cause smoke is reading wrong.
PS: Your title is a bit misleading, the Duratec is the petrol engine, the 1.6TDCI is a Duratorque!
