Pulling to the left.
My focus is pulling to the left. I’ve had the tracking looked at. I’ve had it in a garage all day getting checked over and he said everything is fine. I’ve been advised to change my tyres around see if that helps. Has anyone had this problem or any ideas what else I could check. Sorry if this has been asked before.
dont think your tyre will cause the car to pull to one side unless you don`t have the correct air-pressure in them.
so when they checked your tracking and front wheel alignment it was all ok then ?
tyres can cause pulling to one side( normally to the left) and often to the non tech there apears to be nothing wrong with them.
have the wheels swapped front to rear and see if it fixes .
