Focus MK2 Aluminium Pedal Kit
I'm sure this has been asked before but I would like to know before I consider buying - is this going to be compatible with my MK2 Focus?
https://www.fordpartsuk.com/shop/ford_focus_aluminium_pedal_pad_kit_rhd_f_1534426_c_342.htm
I'm sure I can get it cheaper, just need to know for the part number
Hi , all 3 pedals just go over the existing ones but need to pull off old rubber ones.
As for the foot rest you get a couple of screws which screw in carpet. Like i did.
The mk2 is not much difference from mk2.5.
Sent from my SM-G925F using Tapatalk
Btw mine is mk2.5 titanium - S
As far as i know its same for mk2 & mk2.5
Yunii
That page that you linked to states:-
Fits Focus From:From: 03-12-2007 To 01-07-2011
Have a look on eBay or Amazon etc.
I did see that, but searching eBay for the part number says it's for all Focus' from 2004 up to 2011, hence the question! It's all a bit confusing but I might ring my local dealer as they're quite good at confirming part numbers for me
those ford jobbies that were linked  look a bit crap if im honest , and are completely over priced.
if you gonna do the pedal mod , do it right - use sparco.......   ;-)
https://www.demon-tweeks.co.uk/performance/pedal-extensions-footrests/sparco-reflex-pedal-set
They might be crap, but I'm a stickler for OEM stuff (but 100% overpriced!). I'll take a look at the Sparco stuff, though
Actually they're not too bad.
Yunii
Although agree with it as over priced.
17 hours ago, mrmetallica said:
I bought my replacement headlight from that eBay store as it happens
