damp smell
iam getting a damp wet smell like if water has dryed up, but only when I use wipers I have toped up screen wash bottle with new screen wash which was already mixed but that just smells like screen wash lol,, all carpets are dry to
check under your spare wheel for leaks there's a lot of post about it on the sites:smile:
ok I look later and reply back
do you use the air-con in the car ? if so your pollen filter may need replaceing
ok back again boot well is nice and dry seems I pin pointed the smell only comes on if I use the heating  on 1 or 4  and wash windows the same time only smells when cleaning front one,,so if heating is turned off and I clean front window no smell
replace pollen filter in the car, and that will solve your smell problem :rolleyes:
so is the smell down to the pollen filter its a funny one because I have heating on for a good 20mins driving no smell at all as soon I wash front window I get smell only smells until water is wiped from window
Spray your window (maybe with wipers lifted off screen), and then go and smell the washer fluid. Washer fluid can go bad (and stuff can grow in it if not appropriately mixed with screenwash).
i go have a sniff later micro,,lol I no its ok no smell when cleaning back window,but don't if that's because iam up front
The fan won't pull in any odor when you spray the rear window ;-)
update on my smell lol,,its gone now screen wash ran out the other day toped it up only little smell comes from screen wash
