Identify missing screw
In the process of cleaning the MAF sensor in my 63-plate Ford Focus 1.6 TDCi (115), I dropped one of the mounting screws into the engine bay.
Does the screw have a specific technical designation that I can use in order to source a replacement?
I've attached a photo of where the missing screw should live (highlighted in red); in the photo, I've highlighted in green the twin screw (bolt?).
5a4ffb656bad6_FordFocusMAFmountingscrewmissing.thumb.jpg.17cc3dae0b1c61b9a18022eec2815aaa.jpg
The bolts aren't available seperately from Ford, they are part of the MAF kit which is is about £200. :oops:
Stoney,
Thanks for the response. Is there any way of seeing what makes up a MAF kit, that you know of? Something like a parts list?
Basically, I'm hoping that Ford reuse the same parts (i.e. the screws here) for efficiency purposes; if I can get a technical designation or description for it, I can search around.
The Ford parts system (Microcat) does not show the bolts as seperate items and therefore no size information is available.
3 options-
1, go to Ford and pay through the nose for a full maf kit.
2, take out the remaining bolt and get some hardware shop to match a replacement one up.
3, go to a scrappy with a screwdriver and scrounge one out of a scrapped car (most Ford models and many Volvo's use the same maf so bolts should match).
