Escort MkIV indicator fuse blows
Can anyone help? My 1991 MkIV Escort blows fuse no 13, but not immediately.  The flasher unit randomly clicks and then finally stops altogether, and the oil warning light goes on, even though engine running fine.  I have changed both steering column switches and flasher unit - no change. Maybe direct short in wiring to reversing switch and lights, also supplied by same fuse ? but Where does the loom go?   Does anyone know?  Many thanks.
Try checking the indicator units for water ingress,this could be causing an intermittent short.
