Weird FoCCCus Issue
Evening,
So I can download FoCCCus from thier website, extract the files and then immediately open the programme - bit only if I 'run as admin'.
But after I close the program and try to open it again, the program/app icon completely disappears from the folder.  I tried creating a desktop shortcut which worked while the program was already open, but didn't lead anywhere next time I tried.
So I've been downloading it each time I want to use it, not a massive issue I know but I'd rather it just worked like any other program.
Any idea what I'm doing wrong?
what system you are using ?
Windows 10 laptop
Ive had similar issues and if the same its to do with Windows Defender. open up defender and add the FOCCUS folder to the excluded list. (or temporally disable it) Certain programs have abilities that windows simply doesn't like, if it behaves in a certain way, windows can hide it from you for your own safety
Not saying that's definitely whats wrong but its certainly possible
Other alternatives are POS software interfering, such as Norton or McAFEE in almost every instance ive supported people with PC problems, those two feature in the most likely causes! they can basically do the same as what windows defender does and nuke it the moment you access the file
I don't have Norton or McAfee so can rule those out!  Will have a look at Defender now.  :smile:
I can't find the excluded list on the current version of defender... :unsure:
Open Defender
Click - "Cog" diagram, bottom left-hand corner
Click - Virus & threat protection settings
Scroll - Exclusions
Click - Add or remove exclusions
That seems to have solved it, thanks both of you! :biggrin:
