Ford KA 2010 - Heating blowing cold
Picked up 2010 Ford KA for daughter and heating blows cold until you crank up the fan speed and their is a "pop" sound under the dash that suggests a plastic valve opens and allows hot air to enter the cabin. Suggests that this valve is sticking and just needs a blast of air to release this. This is a pain as it does need a few efforts at times to get this flap open - no good for my daughter when she is without a clear windscreen!! Can anyone confirm what this is and how it can be simply resolved.
I thought at first it could be the heater control valve, but I don't see how increasing the fan speed frees it off.
Other thing I can think of is the blend door is getting stuck, and is probably an actuator failure. Couldn't tell you where they are located on a KA though.
Thanks for your reply. Hopefully someone knows where the actuator failure is or it's off to the local ford dealer.
  • 1 month later...
  • 4 years later...
HI
Did you find the problem to this
I have the same model and problem
thanks
mike
