Wheel drum
Going to take back drums of tomorrow seen that you can use 2 bolts to pop them off any idea what size bolts do i need
8mm bolts will do the trick.
Get the drums warm first by running with the hand brake on for a bit. Some heat always helps.
ScaniaPBman.
all good dudes bit wd40 around them 2 bolt holes used 2 bolts come off easy most be because no meat on shoes lol so order some
Careful with WD40 around brakes... It's fine as you're replacing the shoes this time but you don't want it on the friction material in future.
