Radio Upgrade
Hi, I’ve recently purchased my focus st 2007 plate and looking to upgrade the radio.... any suggestions?
Xtrons or Eonons Android head units usually do the trick.
You will need the appropriate patch cable, remote interface and a fascia adaptor (the standard Visteon unit is not a true double din size).
I’ve currently got the sony radio, would it be as easy as taking it out and replacing ?
Oval or rectangular?
If oval you just need loom and remote interface.
Rectangular needs the fascia adaptor as well as Ford rectangular radios are bigger than standard double din.
It’s the oval one, do you have a link where I could purchase
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F362236992527
I believe this kit comes with the stalk remote interface and all loom cables.
You need to connect a wire to the handbrake system to enable video playback but should all be in the instructions.
Some club members have fitted this type of kit so you should be able to obtain plenty of practical advice on the forum.
