Intelligent AWD Display
Whilst driving in the snow, I thought it would be interesting to watch on the dash how the power is distributed between the wheels, but I was disappointed to see that when the ‘Intelligent AWD’ is selected, the power is only displayed as going to the front, going to the rear, or going to both.  It doesn’t appear to change to show which side of the car is getting power.  I was expecting it to shift left and right as well as forwards and backwards.  Does anyone else’s car show side to side split ?
It doesn't do side to side only front to rear.
All-Wheel Drive (AWD) Systems - All-Wheel Drive (AWD) Systems - Overview
Print Print Report An Error Report An Error
Description and Operation
General Information.
The AWD (all-wheel drive) system comprises the following components:
  • transfer box
  • Propeller shaft
  • Rear drive unit with integrated active torque coupling
  • Rear drive halfshafts
  • AWD module
The AWD system is an active system. It responds to wheel slip between the front and rear axles to transfer torque to the rear wheels before the slip occurs. The AWD system is active all the time and requires no input from the driver. The AWD system continuously monitors driving conditions and automatically adjusts the torque distribution between the front and rear wheels. During normal operation, most of the torque is delivered to the front wheels. If wheel slip between the front and rear wheels is detected, the vehicle is under heavy acceleration or the vehicle is in a handling maneuver, the AWD system increases the duty cycle to the active torque coupling (ATC) solenoid. The ATC solenoid meshes a control coupling into the rear drive unit, which sets a ball ramp device in motion. The ball ramp device applies the main clutch pack in the rear drive unit and increases torque to the rear wheels as necessary. When the AWD system is functioning properly, there should be no perceived speed difference between the front and rear axles when launching or driving the vehicle on any uniform surface.
AWD control and fault indicators
Using inputs from various module/systems, the PCM (powertrain control module) sends a command to the AWD relay module which controls the amount of torque sent to the rear wheels by sending a PWM (pulse width modulation) duty cycle to the active torque coupling solenoid. AWD system faults are indicated by a driveline icon indicator in the IPC (instrument panel cluster) as well as the "Check AWD" message in the message center.
Spare wheel and mismatched tire sizes
If the spare tire is installed, the AWD system may disable automatically and enter FWD (front wheel drive) only mode to protect driveline components. If the AWD systems detects one tire is 5% larger or smaller than the other tires, it may also disable the AWD system. This status can be indicated by a "AWD OFF" message in the message center. If there is a "Check AWD" message in the message center from using the spare tire, this indicator should turn off after reinstalling the repaired or replaced normal road tire and cycling the ignition OFF and ON. It is recommended to reinstall the repaired or replaced road tire as soon as possible. Major dissimilar tire sizes between the front and rear axles could cause the AWD system to stop functioning and default to FWD to protect the AWD system from damage. If this condition occurs, a DTC (diagnostic trouble code) is set and a "Check AWD" message is displayed in the message center.
AWD bar code identification
The vehicle's AWD system controls the active torque coupling using a solenoid. Due to response rate differences within the AWD hardware, the PCM must know the response rate of the active torque coupling. This can be achieved by programming the bar code information for the active torque coupling into the PCM. The PCM uses this bar code information to match the clutch characteristics of the active torque coupling solenoid with the desired output torque. If the bar code information does not match the PCM information, driveline damage or driveability concerns can occur. When replacing the PCM, the new PCM must therefore be configured with the bar code information of the existing active torque coupling solenoid.
Installation position of the bar code sticker with the configuration data for the active torque coupling
Click to resize E169588
Item Description
1 Bar code sticker for active torque coupling solenoid
Configuration of the active torque coupling
NOTE: Rear drive unit damage or driveability concerns can occur if the bar code information for the active torque coupling solenoid is wrong.
NOTE: The 4-digit numerical bar code can be found on the sticker on the rear drive unit.
AWD driving cycle
NOTE: A careful driving style and respect for the rules of the road are vital.
1. Carry out 3 accelerations from 0-48 km/h (0-30 mph) in a straight line.
  • Perform this process with the accelerator pedal at the low engine speed position, medium engine speed position and at the wide open throttle position.
  • Make sure that there is no perceptible slipping of the front wheels.
2. On dry road, drive the vehicle at 8 km/h (5 mph) with the steering wheel turned to full lock.
  • Make sure that no "straining" of the power transmission system occurs.
Active torque coupling solenoid
The active torque coupling solenoid is integrated in the rear drive unit and applies clutch pressure as controlled by the AWD relay module to increase or decrease torque to the rear wheels. The rear drive unit transfers torque from the drive shaft to the rear wheels depending on the specific request from the FWD system module (PCM).
AWD relay module
The AWD relay module receives the command from the PCM, and in turn supplies a PWM output to the active torque coupling solenoid for the requested torque to be applied.
Great bit of info there Hamster. Thanks 👍
Cheers Hamster.  Explains it all very well.  I just thought it was cleverer than that, like the EBD system is for brakes.
