airbag light
hi all
looking for some help with airbag light streetka 2004
light flashes 5 times then goes solid
checked connections under seats been searching for codes cant find a diffinitive answer but
was thinking about getting a control module from scrapyard
thing is i dont know the location of this on the car if anyone can help with codes or location
or if the ford ka fits streetka would be much appreciated
thank you
hi
update after reading about codes i think the 5 flashes are in fact single flashes
apparently its supposed to start a sequence
theres a 2 second pause between each flash then goes solid
been trying to work this sequence out but im stumped
cheers
Why don't you get the fault codes read? Instead of guessing at what might be wrong?
hi
i cant drive car mot is out this is why im trying to find out if anyone had an idea
going for mot saturday morning
Remove steering wheel, unplug airbag wiring harness, spray switch cleaner inside plug, clean with cotton bud. Job done. Always disconnect the battery before working and Wear safety glasses.
