Mondeo 2010 diesel keep regenerating
Hi guys, Mondeo MK4 diesel 2L
So new dpf fuel vaporiser fitted because old one was filled with carbon and i was getting the DTC codes that couldn't regenerate because couldn't reach the proper temperature in bank 1,plus other 3 DPF related DTC codes regarding high soot level and forced reduced power.
Driving in this condition for 3 weeks .
Previously the temperature was not going more then 430c.
Now the new vaporiser is fitted...the temperature are reaching a max of around 560c (see photo) while driving at 60miles down the motorway in 3rd gear,the engine fan is ON too as u can see.
The problem is that it never stops the regeneration... everytime I start the car instantly the fan kicks in and the temperatures go up to around 550c.
What I noticed that as soon the regeneration start all the fuel data on dashboard disappear too? Plus fuel consumption is now sky high.
No DTC codes and car drives ok
Suggestions please
Thanx
eb7301c933ccc2999e583b6e193d0ae1.jpg&key=6eca6642cddacb8ad809ff349ef2d4df6bd8d85ea1227c20b377d5b0e05c91146da4b77de0f024168bc25e5c99e13b26.jpg&key=0d3480588726616638906592952cca3eb616789de5144ad675e86a921d74d34b4619ee2de212f732b827ac01828730ea.jpg&key=e06bbe6d20a8addcbd0b994a37406cd7f04e4f47ae085a6acd8632dcc3400d19
Sent from my Pixel XL using Tapatalk
Does it still show codes for high soot, could be the DPF is blocked
No no codes....,car drives ok, DPF pressure 0 at idle and no more the 5 at high revs.
Can I reboot the ECU?what tells the ECU to do a regeneration? The DPF pressure sensor? Forscan don't show any soot level data. Thanks
check the dpf sensor pipes at the dpv for brittle/broken pipes
Done that but no luck.
