Access Rear Light Bulbs On Mark 7
1. Open boot and remove the 2 screws attaching the light cluster to the back of the car. A small flat blade or a torx 25 screwdriver will do it.
2. Inside the boot pull back the side carpet behind the cluster. Starting at the boot-latch end ease out and pull back the carpet all the way to about halfway back towards the rear seat. There are no clips to break it should come out pretty easily
3 You now have access to the back of the light cluster. There is a small rectangular hole there and just inside that you will find a long wingnut. Unscrew and remove
4. The cluster can now be eased out. There are no clips to break, just 2 push studs on the outside of the cluster which can be pulled out of the back of the car.
5. Before removing it too far disconnect the wiring block at the back so that the cluster becomes free.
6. The bulbs are held into the cluster by two clips - press those back and the bulb section can be removed
Moved to fiesta guides try and attatch some pictures :)
  • 7 months later...
Do you have the link of where this has been moved too?
Cheers
Cheers
Right here :p
Do you need to remove the wing nut before accessing the rear bulbs?
Cheers
Cheers
You sure do.
Probably worth adding that not sure there is really any point in having the wing nut on? I took mine off and left them off and they have been fine since.
