2008 Focus Tsb
Hi All,
Is anyone able to give me the details of TSB 27/2012 dated 14/05/2012?
Regards
Pezza
I collected a lot of TSB files from the internet over the years. I have got the following information about the TSB you requested. Note that I deleted some non relevant information. Also note that this Ford TSB is no (warranty) recall. The TSB's are only a guide for the mechanic containing known problems and solutions. If the car is not under warranty you have to pay yourself for the repair.
TSB 27/2012
5/14/12 Excessive combustion noise and or hesitation during light load acceleration with the engine at high operating temperature
Subject/Concern: Excessive combustion noise and or hesitation during light load acceleration with the engine at high operating temperature
Model:
Focus 2004.75 (07/2004–07/2011) - stage 4 emission level only Build Date: 07/2008-12/2009
Build Code: 8D-9E
Assembly Plant: Saarlouis
Assembly Plant: Valencia
Engine: 1.8L Duratorq-TDCi (Lynx) Diesel
C-MAX 2003.75 (06/2003–07/2010) - stage 4 emission level only Build Date: 07/2008-12/2009
Build Code: 8D-9E
Mondeo 2007.5 (02/2007–) - stage 4 emission level only Build Date: 07/2008-12/2009
Build Code: 8D-9E
Assembly Plant: Genk
Transit/Tourneo Connect 2002.5 (06/2002–) - stage 4 emission level only Build Date: 05/2008-01/2010
Build Code: 8C-AL
Assembly Plant: Kocaeli
Markets: All
Summary
If a 1.8L Duratorq-TDCi (Lynx) engine vehicle of the stated build periods, is noted for excessive combustion noise and or hesitation during light load acceleration with the engine at high operating temperature, please check the fuel injector nozzle part number. If the fuel injector nozzle part number end in 3, revised calibrations have been released to improve the fuel injector nozzle performance. These calibrations should not be applied if the fuel injector nozzle part number ends in 2.
This bulletin contains a list of the revised PCM calibrations which should be loaded, in order to rectify the concern.
NOTE: Use IDS-78.05 DVD and IDS-79.01 or a later version.
For markets where FordEtis IDS is used, refer to WB 45/2009 for the policy on using FordEtis IDS for warranty repairs. If FordEtis IDS is used to diagnose a customer's concern(s), select the appropriate customer symptom(s), follow any diagnostic, repair and post repair procedures presented, and ensure the completed diagnostic session file is transmitted to Ford. Failure to follow this process may affect any associated warranty claim submission. For markets where FordEtis IDS is not available, rectify this concern by following the attached service information.
Service Information
See Summary.
For markets where FordEtis IDS is used, connect FordEtis IDS and select the appropriate symptoms from the concern descriptions above. Follow the FordEtis IDS instructions to rectify this concern.
Item Description
- Inspect the part number of the fuel injector nozzle. If the part number end in 3, update the PCM calibration. New calibrations have been released via FordEtis IDS to compensate the fuel injector nozzle loss of performance.
NOTE: These calibrations should not be applied if the fuel injector nozzle part number ends in 2.
NOTE: Before commencing module configuration or programming, connect the vehicle battery to a suitable external power supply in order to maintain a constant battery voltage throughout the procedure.
1. Reprogram the PCM using IDS.
C-MAX 2003.75 and Focus 2004.75
Vehicle PCM calibration chain (12A650) - Increased energy PCM calibration
C-MAX 2003.75 7M51-AU* (e.g. 7M51-AUK) update to 7M51-BPA or later
Focus 2004.75 7M51-BC* (e.g. 7M51-BCG) update to 7M51-BNA or later
Mondeo 2007.5
1.8L Duratorq-TDCi (Lynx) Diesel PCM calibration chain (12A650) - Increased energy PCM calibration
92kW/125PS with 5-Speed Manual Transmission 7G91-P* (e.g. 7G91-PJ) update to 7G91-AEA or later
92kW/125PS with 6-Speed Manual Transmission 7G91-Y* (e.g. 7G91-YK) update to 7G91-AGA or later
92kW/125PS with 5-Speed Manual Transmission Econetic 8G91-J* (e.g.8G91-JC) update to 7G91-AFA or later
Transit /Tourneo Connect 2002.5
1.8L Duratorq-TDCi (Lynx) Diesel(*) PCM calibration chain (12A650) - Increased energy PCM calibration
55kW/75PS without Diesel Particulate Filter (DPF) 7T11-H* (e.g. 7T11-HP) update to 7T11-BA or later
66kW/90PS without Diesel Particulate Filter (DPF) 7T11-D* (e.g. 7T11-DP) update to 7T11-EA or later
55kW/75PS without Diesel Particulate Filter (DPF) 9T11-H* (e.g. 9T11-HJ) update to 9T11-JA or later
66kW/90PS without Diesel Particulate Filter (DPF) 9T11-GJ* (e.g. 9T11-GJ) update to 9T11-NA or later
(*) Turbocharger with fixed turbine geometry only.
Fantastic reply, just what I needed.
Ford have basically been lying to me that this TSB doesn't exist and want me to pay £1500 for new injectors on a 2009 1,8 TDCI with 49K on the clock. They have not mentioned anything about the PCM update to cure the batch ending in 3.
Ford confirmed last week all 4 of my injectors are in the batch ending in 3 however when I asked if this was a documented issue the categorically said no it was just know amongst the local dealers.
Is that image on the link I posted above an official picture from the bulletin?
I would have thought if they knew there was an issue with this batch then Ford should replace them instead of a PCM update to work around the issue?
Cheers
Pezza
TSB 27/2012
Model:
Build Code: 8D-9E
Build Code: 8D-9E
Build Code: 8D-9E
Build Code: 8C-AL
Markets: All
Summary
Service Information
See Summary.
Item Description
Mondeo 2007.5
out of curiosity what are TSB reports and how do I check if any have been issued for my focus over the years and where to get them?
Hi.
They are technical service bulletins, there what the Ford mechanics look at for advise on issues.
They are not readily available on the internet, I had to seach for the reference and JW1982 very kindly helped me out.
Cheers
Allister
Hi.
Cheers
Allister
Thanks, its good to know this information.
