Door handle reinforcement mechanism
Had a problem with my driver's door handle which now won't open the door from the outside, but perfectly fine from the inside.  I heard a sound as if a piece of metal fell down the inside of the door when it happened and from reading up on the internet it sounds as if its a piece that has fallen off the reinforcement mechanism.  I'm surprised it doesn't come up on a search on this forum, so my question is: how easy it is to take the reinforcement off but then put the handle itself back on for the time it takes me to confirm this is the problem and then get a new one?  Depending on the cost new I might try to get one at a scrapyard but want to make sure I'm only buying a piece that I really need.  Does anyone have any tips on what else it might be or tips on a fix - theres a video on the US Youtube showing a cost free fix but I don't think its relevant to this problem.
thanks
It is certainly worth getting the door trim panel off. It is one of those fiddly jobs, working out just where all the clips are, etc, that will be much quicker 2nd time around. Then you can have a good look inside, & maybe locate the bit, before further decsisions.
Yeah, I'll have to do that anyway, but thought it would be better going into it with the combined knowledge of this forum,especially if there is a common issue to look out for.
  • 1 month later...
So I finally got around to taking the door panel off, but there is a solid plate across the whole door so can't see into the handle mechanism at all.  The Haynes manual has a whole list of things to remove before even getting to the window regulator, including:
*  remove the window glass
*  remove electric window motor
*  remove the exterior door handle
*  remove the door (!!!)
*  remove the exterior mirror trim (???)
*  undo the 10 bolts securing the inner panel to the door frame
*  undo the 5 bolts securing the door lock to the door
*  manoeuvre the panel fro the door
*  drill out the rivets holding the window regulator
Sounds a lot of faff just to get to the inside of the door frame.  I have tried taking off the 10 bolts holding the panel but it won't move.  Maybe I will try by  undoing the bolts holding the window motor as well and the ones holding the door lock, but the last thing I need is for the window glass to fall out or the electric mechanism to not work as well as the outside door handle, then I would have to start climbing in from the passenger side every time I want to drive the car.
Hoping that someone has done this at least once and can give me some reassurance that it all goes together without a risk that nothing works afterwards.  Photo of the door with the trim off so you can see what I am looking at.
thanks in advance
Have you removed the outer door handle to check its not broke before taking all this apart?
Good thinking.  The handle still springs back in the normal way but I have just  taken it off in case and it looks intact.  The spring mechanism looks ok from the little I can see from the outside through the hole - if I had an endoscope camera that might help, but I don't.  I think that either a piece of the reinforcement mechanism that I can't see has broken off, or the wire connector hook has come off somehow.  I heard a noise like a metal piece falling down the inside of the door when it first broke so the challenge is getting in there to find it or fix it...
By the way, you don't need to remove the door.lol the window does need to come out though. The door handle mechanism comes with the metal panel including the window regulator. All in one piece. Also you will need to unclip all the wiring harness from various connectors and clips if you leaving the door on.
There's 2 access holes that will enable the window to come out, 10mm bolts. Lower the window until you see the bolts. And loosen but don't need to remove all the way.
OK, thanks for that.  So to summarise:
1. pull out the window from the door - the Hayes manual seems clear enough on that, confirmed by what you said
2. undo all the electrical connectors
3. unbolt the electric window motor
4. unbolt the metal panel and remove to get access to the insides and the handle reinforcement will be attached to the back of it
What about the lock mechanism - does this need to come off as well to allow the panel to come off?
Do you know how long all this should take, and the chances that it all works when put back together?  Worst thing would be to have no door handle or windows working!
Leave the motor bolted. Undo the screw that holds the outer handle mechanism( should see it now you have outer handle off. The only connector you can't undo is the one for the door latch, that will need undoing as you manoeuvre the metal panel, the wiring for it is clipped in from behind also. You will see what I mean when you look.
Just be patient when manoeuvring it all out . It will all come out at an angle. Also remove the interior handle and cable with it unless your careful to remove the cable from inner handle(can break easy)
Got it - well at  least the door is in bits now!
The broken part is the cable connector that runs between the handle and the lock as in the photo.  I have included a photo of the back of the metal panel as well in case anyone is interested.
I'm hoping the replacement cable can be bought on its own - its only a short length of cable less than a foot long with connectors crimped on so shouldn't be that expensive.  Would you happen to know what it is called (or part number) and if only Ford would stock it?
Thanks again for all your help Ian, it feels good to  have worked it out without resorting to a mechanic, and will feel even better when all fixed and working.
Opps, last photo upside down for some reason
no idea if that cable comes as a seperate part . ive never replaced one . i would describe it to your ford dealer and they should know what you need
Great topic guys. Well done
Quick update after sleeping on it overnight...I decided that  the chances of buying the cable on its own for a couple of quid are unlikely especially as it passes through a sleeve which would have to come with it if the cable already has the end pieces attached.  The sleeve is clamped onto the handle/catch mechanisms and looks like I could easily snap a piece of plastic and be back to having to buy the whole attachment.
So I made a new attachment piece for the end of the cable where it broke - I used an electrical connector and crimped it onto the end of the broken cable and then fitted it onto the door reinforcement using a small nut and bolt - hopefully the photo shows that ok.  It seems to work and operates the door catch, but I'll only know when everything is back together.  How long it lasts is another question but at least having done this once it will be quicker next time.
Now to give everything a bit of a clean and lubrication - amazing how much crap ends up inside the door behind the panel...
good try but i doubt it will last too long, at least you know what you need to buy next time prior to dismantling again.
All put back together and the handle is working as it should...for now, lets see how long it lasts.
A couple of small issues - why is the trim so hard to put back together so it is all aligned and not floppy?  A couple of the fasteners on the door card wouldn't clip back in and I didn't feel like taking the thing off again - one might have broken off when I pulled it off first time.  Same for the bezel around the inner door handle which took ages to align and clip back in.  The other thing is that the drivers window does not do one-touch close any more, but does one-touch open.  All the other windows still do one-touch up and down as before - does this need to be reprogrammed, or is it that I might not have put the window back in properly?
Anyway, I'm still happy I've done this work myself - learned a few things and didn't need to take it in to get it looked at and probably pay someone else a couple of hundred quid so happy days.
window just needs re learning.
