1996 Mk4 Reverse Sensor Switch Location
Hi all,long time no post!
Can anyone tell me where the reverse sensor/switch is on a 1.25 zetec motor pls(photo's would be helpful too for anyone else for future reference)?
My reverse light has packed up and I'm sure its the sensor,its not the bulb as my rear lights work ok and it has been an intermittant problem as when the reverse is engaged,the light goes on but let go off the gearstick,it goes out.
thanks in advance.
Andy
There are 2 different types but its usually a square plastic switch about 2" x 3" in size , black and white fitted on the box.if not it will be a metal circular switch down on the front of the box
Is that near the oil pressure switch bottom r/h side of engine?
no on the gearbox itself not the engine
did ford update the gearbox from the 2 wire switch to a sensorbox unit?
Yes that is the square block I mentioned
thanks very much bud, my mates going to check all the fuses and connections before i start spending on the new parts:)
If you got the square type fitted its £30.11 + £3.00 delivery.
0191 4200168
0191 4200168
can get a new genuine ford ib5 switch on ebay for £27 and they are only 12 miles from me but thanks anyway :)
