Clutch
jericho200
i have a problem getting into gears i have been told that the clutch might need bleeding can this be done?
if so how would it be done?
many thanks
it's a 96 galaxy
get a haynes manual it should be in there :)
if its hydraulic you can bleed it, if its a cable you should be able to adjust it.
bleeding hydraulic clutches is a PITA at the best of times, really needs to be pressure or vacuum bled.
hi m8
sorry to be the bearer of possibe bad news,but i had the same problems and turn out to be the flywheel siezed.are you getting any vibrations through the car?if so then you're looking at flywheel and clutch
  • Sign up to the Ford Owners' Club
    Sign up and be part of the Ford Owners' Club community! it's Free!
