dipped beam height adjustment
2 replies to this topic
#1 Raines005
Raines005
    Newbie
  • Pip
  • 7 posts
  • Ford Model: Focus 2001 TDI
Posted 29 October 2008 - 05:37 PM
Hi All
I bought a focus a few months ago. It is a 2001 model so it has the newer double headlight. It has a button on the dashboard to adjust the height of the dipped beam, but when I use this nothing seems to happen. Does anyone know what could be the problem and how it can be fixed?
many thanks
#2 diamondlock
diamondlock
    Member
  • PipPip
  • 17 posts
  • Ford Model: Ford Focus 02reg 3doorLX
Posted 03 January 2009 - 12:04 AM
Hi All
many thanks
Hi, a bit late in sending this but..... If you remove the headlight cover on the back of the headlight you will see one of two things 1] right in the centre their is a " plastic butter fly - key type". or 2] an oblong box, the later is the motor that drives the headlight up & down if you have the plastic key then you need to replace with the motor, had this happend to a friend of mine when he bought a focus.
#3 SierraYankee99
SierraYankee99
  • 859 posts
  • Ford Model: Ford
Posted 03 January 2009 - 12:42 PM
The motors arent cheap either. About £70 each IIRC. Might be better to source a couple from scrap yards if you can, but be very careful they are a sod to get out without breaking the little ball off the end.
