Starter Motor Help
Hey guys. My fiesta ha the battery die the other day. Charged it off the car and refitted it. Started perfect first time. Went out in it parked up etc. came back to it later and all I get when I go to crank it is a loud click. Battery seems to be perfect and car starts when bumped. Can someone please shine some lift on this please?
Thanks guys!!
Can anyone help please? I'm in a rate mess without my van!:,(
How old is the battery?
Not very I believe
The power doesn't dip when attempting to start like it did when it was almost dead
Sounds like a loose connection, have you tried tapping the starter motor with a hammer?
Also make sure the battery connections are tightened up correctly. One member not too long ago had a similar problem and it was due to a loose connection after replacing his battery
I've checked the battery connections n will try tapping the motor tomorrow when I'm in the pit. Thanks.
Check all connections on battery, starter motor and any others inbetween
Sorted it I think guys I have the motor a hit or 20 and cleaned the connections.
