radio/cassette to cd/radio change
hi i have a 1996 fiesta 1.3, it currently has a ford 3000 radio/cassette. does anybody know if i can do a straight swap to a ford 6000 cd/radio or do i need anything extra? cheers
You might need a radio code.. but apart from that i think everythin is all the same..
need 2 double check as im not 100% sure!
hi, with it being ford to ford you shouldn't need to change it really, you only really need to change it if its from a standard ford radio in the car to a after market radio, if you're doing that then you need to buy a harness adapter
yes just done it on my daughters 98 model fiesta. dont forget the radio code. you need either the radio removal prongers or four bits of welding rod or a chopped up wire coat hanger. The unit are swapped by cable only. DD din size. you should have no problem at all.
