mondeo headlights
Hello,i have some fault codes from my headlamp control module which i need some help with,the codes are,
b1c98-11-6c
b1c98-13-6c
b1c99-13-6c
b1a57-87-2f
any help please?
Update.problem found,passenger side headlight connecting block badly coroded.bought a s/h headlight with cleaner bolck fitting monday.
Glad your sorted
  • 1 year later...
Any ideas people? my titanium 2009 had failed on my headlamp unit being loose. I am presuming that is the casing to hold the light in place but apparently there are 4options and the one I need is called a fishtail model but I am being told the garage can not find a stockist for it anywhere in kent and they have even started checking ebay . Anyone ever had this problem or know why the unit is so hard to get?
Try and get and give a bit more info. Are they xenons? Maybe 'fishtail'  is garage slang for what it really is. There will be a proper Ford part number for it... called a finis code, its 7 numbers long and Ford's spares centre is located in Daventry,  and its massive. Unlikely they won't have the part there. Have you tried a Ford main dealer? What did the mot fail report actually say.
