Erratic electrical problem.
Hello, I have a 2007 Focus style, 1.6, petrol and it has recently having erratic electrical problems. When I turn the key to start the car just before the engine turns over sometimes the windscreen wipers come on for a second or two,  and a warning beep or two or 3.
The other day when I was driving all the instrument cluster lights went on, a few seconds later the lights went off. This has happened a few times.
The other day the temp gauge went to the top when I started the engine, the engine was already warm from driving earlier. The engine was not overheating. Next time I started it it was fine.
The petrol gauge showed empty when I know I had half a tank full.
The engine cuts out when driving, and when I started it up again it just died, until I start it up and rev the engine. This has happened a few times.
I know a bit about cars and mechanics,  but electrics are not my strong point. I would be grateful for any help or advise. Thanks.
I will clean up any earth connections just in case
How old is the battery? Might be worth getting that checked/tested to start with. Strange things happen (like the wipers) when a battery is on its last legs.
The battery is at least 3 years old. I will test it tomorrow. Thanks for the reply.
might be your instrument cluster
  • 3 weeks later...
I changed the battery and that cured the electrical problems. I also changed the ignition switch and that has stopped the car from stalling. All is good for now.
