Mrk2 Ztec S
Alright guys
I'm looking at a set of mrk2 RS focus bucket seats at the moment.
Do you recon these will fit into a 2010 mrk2 Ztec S ? Becides having to swap the rails over and modifying the airbag electrics . It should be a straight forward fit?
Ang experience would be appreciated before I buy them.
Cheers
1 hour ago, Deaks555 said:
Alright guys
Do you reckon these will fit into a 2010 mrk2 Zetec S ? Aside from potentially having to swap over the rails and modifying the airbag electrics . It should be a straight forward fit?
Any experience would be appreciated before I buy them.
Cheers
If there mk2 RS seats then there a straight swap in to a mk2 focus,
Need a TX40 and a TX50 Torx bit to remove front and rear seats,
Both torx bits are available in a socket wrench fitting from Halfords; keep reciept can be returned if your only using once
If you have a 5 Door focus; take off the bottom of the rear seat first,
Then take the front seats out through the back doors,
In theory the airbag loom connectors should be identical; The only question is whether you have heated seats in your focus as the RS seats have a heated option which could work if you had loom already fitted but if you dont; I wouldn't bother fitting the heated loom too much bother.
