SEAT MEMORY
Does anyone have a schematic for the seat / mirror memory function. As far as I know mine has not worked from new and Ford are being less than helpful with my local dealer.
Martin
What kind of diagram do you need?
Anything would be helpful !
Are you sure you're setting it up correctly?  Does the memory function work on the door buttons and not the fobs, or just not holding settings at all?
The fobs are admin fobs. Doesn't set at all. Hold button in for as long as you like but no beep and no position set.
Are you doing it with the ignition 'on' ?
There is a fuse for the memory function, separate from the adjustment fuse, looks like it's number 2 in the interior fusebox, might be worth  check.
  • 4 weeks later...
Module ( under driver seat ) tests faulty ! New module on order but may take a while !
Thanks to all for the suggestions.
  • 4 months later...
Memory Function:
Is seat position always included.
mine don’t work!
