Mk2 12v socket casing
Hi all,
I've recently got a second hand '08 (mk2) Focus, and a part I'm looking for is the plastic collar that goes around the 12v socket that goes by the gear stick - it's broken. I've managed to jam a wedge in it to stop it from coming out but does anyone know where I could purchase one?
Thank you
2 minutes ago, OmarEbrahim said:
Hi all,
Thank you
try e bay 😊
Ford part number (finis code) is 1561267.
Either request it from your nearest Ford parts counter or from here-
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F182410741148
I know it says ignition switch bezel but that's because it is designed to take either the 12v power socket or a start / stop button depending on the cars spec.
Sent from my SM-G965F (S9+)
Lol I must of been searching for about an hour I did come across start/stop and thought they looked similar well done!
That's perfect, thank you! 😄 £11 is a bit steep for a bit of plastic but it's ordered
It was handy that as I did a console upgrade on an old mk2 I did a guide within which was the correct part number.
Double checked on 7Zap and all good.
That's perfect, thank you! [emoji1] £11 is a bit steep for a bit of plastic but it's ordered
The fiddly parts usually aren't cheap. [emoji848]
Glad to be of assistance.
Yes, Ford are excellent for charging extortionate prices for small bits of plastic LOL
You think Ford are bad for it (they are), try purchasing the equivalent Audit/Mercedes part brand new.
they all do it 😊
