Windscreen washer problems
Hi everyone,  I have a Ford Focus Titanium X from 2013 and my windscreen washer stoped working although the headlamps washer works. I have checked the fuses, all fine, I have replaced the pump and still not working , I found out that the old pump still works. Anyone had the same issue in the past , please advise.  Many thanks.
Have you checked fuse 77 and 82? And is it both front and rear
Also check the connector for the washer pump carefully for any corrosion.
As the headlamp washers are working , the switch must be sending the wash signal to the body control module.
Also check for corrosion at the body control module connectors.
I have checked the fuses previously nothing wrong with them but not after I have replaced the pump. I did checked again after a couple of days and it was fuse 82 blown. All sorted and working now.
Thanks for your help
