Sony DAB radio problem
Looks like my Sony DAB radio have a limit problem on how many radio stations/channels it can receive.
Alway missing two channels (random). Change to a other radio channel on a different mux and back, then I can listen to the desired channel.
Asked Ford for a firmware update, but they don't understand this problem, and the answer is that there is no new firmware for this radio.
Would like to do a factory default on the config, but have not found how to do that. Some say that a module reset maybe a solution, but how to do a module reset ?
Audio Controll Module
HW=AM5T-14C230-HD
SW=AM5T-14C044-HF
P/N=BM5T-18C815-XF
sync 1 ?
look for a post about  "has anyone loaded sync 1 update ".... you can get the files from ford via the chassis number BUT they are BROKEN how to fix is in that post
search is hopeless... how come u have to google to find stuff on our own forum?
check Phil21185 post about 6 down on how to resolve Fords incompetent software fault or it will never load   read it carefully
HW=AM5T-14C230-HD
SW=AM5T-14C044-HF
P/N=BM5T-18C815-XF
I had a similar issue so I removed the tick from the alternate frequencies box in the sound menu and all seems okay now, hope this helps?
HW=AM5T-14C230-HD
SW=AM5T-14C044-HF
P/N=BM5T-18C815-XF
You could try disconnecting your battery for around 10 minutes to reset your modules. If this doesn't work then visiting a Ford dealer for software updates might work, these can only be done using the Ford ids diagnostic software, most likely at a cost though?
Have tried to remove the tick from the "Alternate frequencies", no change. Still the same problem.
For me it look like the Sony DAB radio have a limit on how many radio station on each dab multiplexor.
