Central locking issue
Hi all have a 2002 Mondeo st 220 have issues with central locking all works fine from key but when you get in the car when you press the drivers door button it only locks drivers door also boot will only open when you double press the button on the key fob done the usual test hold heated button and turn ignition on all doors chime I have noticed if the car is unlocked and you put the key in the lock all doors lock if you turn other way only drivers door unlocks took boot switch out and cleaned the micro switch CAN ANY ONE HELP
