Retro fit satnav on Kuga Zetec
Have 2017 Kuga Zetec.
Is it possible to retro fit a satnav from a titanium/st line model?
Is there a fitting kit available?
If it's sync2 then you can program it yourself,@Bannko is the guru.
If it's sync3 then you should only need to swap out the APIM module and check the roof aerial base is nav capable.
Well 2017 model it is def. a SYNC3 touchscreen or small non touch SYNC1.
So @Batesy what screen is in your car? Without this info we cannot give you further hints.
I have the small screen.
4.2 inch colour screen
@Batesy unfortunately in you case you have to change the whole unit for the navigation one. You can search ebay. Or if you want the big screen you can check this thread, it is for Focus but the procedure applies also to Kuga.
Thanks - I realise I need to change the whole unit, it was the parts I will need or a fitting kit if available
