Service engine soon light and spanner comes on
Hello can anyone help with above quoted problem
Photo attached
Sent from my ONEPLUS A6013 using Tapatalk
Do you have any symptoms as a result of the light on? Ideally you need the dtcs read with a code reader, then we can advise what is causing it. Usually it's a sensor or solenoid at fault.
No symptoms thanks for the advice
You got 3 choices, ignore it and hope it goes away, take to garage and get them to diagnose and fix, or buy a code reader, read codes and decide if it's a fix you can do or garage.
Thank you much appreciated
