Installed My Own Ambient Light
Double sided sticky pads from homebase about £2.50 stuck them on then cut off access works a treat
lol yeh dont think ive got anywhere to go today tho!!... oh btw what did you use to stick them in place... the stuff of the back of mine was a bit rubbish so i used some rather sticky double sided tape and it still comes loose!!
did you change the pin outs?
I'VE DONE IT!! i tried 11 and 12 but it was the same. So i tried 12 and 2 and it worked :D :D
ebay link please :)
  • 3 years later...
Hello,
I'm new to the forum and I live in Belgium.
I have a ford fiesta mk7 with the trend pack and I would add
the ambient light (glove box + empty pocket ) as the titanium pack.
To do this, I bought all the necessary parts to make this improvement:
- Light glove box-set: 1820762 (€ 74.16)
- Light-empty pocket: 1513144 + 1852047 LED (€ 41.75)
I checked behind the plastic (dashboard) but I do not have the cables origins
to make the connection as certain models. (Otherwise connection parameter + change in IDS)
My questions are as follows:
+ With that power must be supplied to LED? 12VDC? (If someone with the pack titanium bit check)
+ Where can I find non-permanent 12VDC?
+ Does anyone tried mounting the headlight switch?
+ Does anyone have the electrical diagram of the car?
A big thank you to all
Ambient lights are usually set to come on when sidelights are on.
Best way is to wire to the numberplate light wire behind the headlight switch.
One wire to the wire behind the switch and an earth to any body grounding point.
I did work out the correct wire colour for someone else recently but cannot recall at present.
I have a full Ford workshop on PDF somewhere, I'll post up the relevant circuit diagram section for you tonight.
Checked and you run a live wire to either of the indicated blue wires (blue/brown or blu/white) for live with sidelights and the black/grey for earth.
post-28494-0-21967700-1395167379_thumb.j
Edited by Stoney871
corrected errors
Hello,
A big thank you for your answer as fast, I think I will succeed with your wiring diagram.
Another little thing, do you think the original LED 12VDC or works with a different voltage?
Sincerely you,
I think it is misunderstood
http://www.zimagez.com/zimage/img125628.php
One to help me
  • 2 months later...
i have followed this guide and got to where i need, however when it comes to splicing the 12v supply, i tried pin 11 and 12 but they only provided 1.5v and when they where connected they turned on the rear fog light. im still trying to fiigure out what pair to splice again without damaging any more wires.
figured it out, I had to take a 12v+ feed from my curtasy light and set the return feed to pin 2 on the light switch. using hte light switch pins only delivered 7v supply wihc did not light up the lights.
