Leaking roof?
Has anyone suffered / fixed this before? I think the seals around my passenger side roof rail has gone at the front & is probably going to be an expensive pain in the ***** to sort 04ab0403ffab3a4682c8520122a31128.jpg
Sent from my SM-G975F using Tapatalk
Sure it's not the windscreen at top left corner?
But if you think it is leaking through roof rails, it's not that bad to remove rail and seal up. Just time consuming as the headlining needs to be dropped to access the retaining nuts. There foam seals but I would just apply a silicone sealant to the area around the holes and refit.
