Focus 12reg Mk3 Ecoboost 1.0 Engine issue
I was hoping for some advice on an issue I've had with my Ford Focus 1.0 Ecoboost. The car is currently at a garage being looked at by a mechanic after having broken down on the motorway and is giving them a couple of error codes. They suggested I run these past Ford before they do any further investigative work on the vehicle. The codes they're getting are:
P000A71 Camsensor Intake Signal
P132B21 Turbo boost pressure sensor
I called the local ford dealer and they just told me they couldn't do anything with the codes (didn't even bother asking me what they were) and i'd need to book the car in for an inspection at their earliest slot which is 3 weeks away.
Also called Ford customer service and they suggested I email [email protected] with the details which I've done, awaiting their response.
As far as what happened, I was on the motorway when the oil light started flickering on and off. It wasn't staying on though. It would flash on and of very rapidly for a few seconds and then go away again for a few minutes, I felt there was a very slight loss of power too whilst it was flickering. It was getting more frequent so I pulled over on to a slip road to try and park it when an engine management light came on and it lost almost all power. I pulled over on to the sliproad's hard shoulder and stopped the car. The engine would still start and run but it sounded rough and had virtually no power. I called my recovery service and they took the car to my local garage.
The mileage on the car is currently at around 48,000. Was a due a full service earlier this year but with the virus situation i'd put it off...Would welcome any advice. Cheers!.
Try list youtube video
Split diaphragm in vaccum check valve = new vacuum pump required.
The fault might be split in the oneway check valve. I would be tempted to buy an inline oneway valve and put it in the pipe, rather than have to payout for a new vacuum pump just to get a new check valve.
just add this or one similar to the pipe.
  • 1 year later...
volvo sell this part separetely, although it still costs around 100$
part number is 31430964
