How to remove Travel FX Radio?
Hey guys, I'm trying to find how to remove the Travel FX radio from my 2010 1.8tdci. I can't find any info, only that apparently you only need a screwdriver? Does anyone have any advice on how I can do this?
Thanks!
The two triangular pieces either side of the radio pop out to reveal screws.  The ashtray/cubby under the climate panel pops out to reveal screws.  The whole front fascia comes away and then there are 4 screws holding the radio in.
You're better off with a trim tool to pop the plastics out as a screwdriver is likely to cause damage.
Gotcha thanks! Do you know what specific tools to buy? Are they just called trim tools?
Looks like I need a torx screwdriver, i'll buy one today.
Yeah, you can sometimes fit a flat-blade across the Torx slots if the screws aren't too tight but buying the correct tool is obviously better!  A selection of Torx sizes is often handy for modern cars anyway.
As for the trim tools, they are just called trim tools, as in Stoneys link.
That's great thank you guys!
