Rear speakers
Hi I have a 2006 ford focus st 225 3 door and I'm looking to replace my back speakers. Would anyone have a video or know how to do this as I'm lost lol.
I've not done a 3 door Focus, I have done a 3 door Punto for my daughter and it was a massive pain in the *****. As the rear trim cards are generally blocked by the seats you'll need to remove them, you may also need to remove the front seat belts too if the bolts go through the trim. It *should* then just be a case of finding any screws that hold the panel in place, pulling the edge trim off and then the panel should come out with a firm tug (steady now!).
You may find the speakers are held in place with pop-rivets, if they are you'll have to drill them out. If you don't have a pop-riveter (who does these days) you can use a rawl plug bent over into the rivet holes to get a screw to bind, you need to make sure they're tight otherwise they could start to rattle and you really don't want to have to take the panels off again to fix that!
I'm not sure what speaker connectors Ford use but they might not fit aftermarket speakers, if they don't it could be worth ordering some adapter cables. It you're handy with a soldering iron you can cut the ends off and solder the connectors that'll come with the speakers.
Good luck!
