Battery upgrade
Hi all my 1.8 petrol Focus needs a battery, at the moment it has a 071 would it be a problem to fit a more powerful 096 in it ? thanks for any advice     Bill
096 is longer so you will have to check that it fits first👍
071= L 266 x W 175 x H 220mm     096=L 278 x W 175 x H 190mm👍
Thanks Richard I think it will go in ok, I have both an 071 and an 096, just wondered if the alternator would handle it
As long as your alternator is generating about 14.6 volts i think it will charge your battery with no problems👍
A Bosch S5 is an excellent battery upgrade
I've fitted one in my focus, as I have alot of accessories, purchased from royal batteries in London during lockdown they delivered the promise in the mist of disaster as im an essential worker and needed the battery but everywhere local was like a ghost town
Thanks for your replies and advice, If it goes in I will fit it, glad to hear about the good service you received from a London company Lenny as I was born in London and am still a proud Londoner even though I now live in West Sussex  Cheers  Bill
It should definitely fit mate, I recently upgraded my wife's 1.8 MK2.5 Focus to a Bosch S5 without any problems.
An in terms of the increased battery capacity, think of it like using a bigger bucket.  it will initially take longer to fill but once full it only takes the same amount to refill as the smaller bucket (assuming neither is getting heavily depleted, which they shouldn't be unless something is wrong).  You just end up with a MUCH bigger reserve of power.
All things being equal the higher the Ah the longer the battery takes to discharge👍
Thanks for all your replies, not had chance to change it yet but will keep you posted for future reference.
look forward to hearing some positive change in the future
Fitted the 096 ok, it was ok length and width but a bit taller so could'nt use the holding down strap and am now trying to make a strap that will fit
Bill
Bill
The 096 is 30mm taller as I said👍
Actually Richard you said the 071 was 30mm taller than the 096
Sorry my mistake.I’ll have another look at that now👍
Just double checked the dimensions, they are correct.The 096 should be shorter by 30mm.Why do you need a longer strap?
Maybe I have brain freeze and not seeing it.
You were probably right with your dimensions Richard but got the height A about F as the 096 is the taller that's why I need a longer strap
According to looking at the spec the 096 is shorter by 30mm.
the length is not the problem it's the height
The 096 is shorter in height by 30mm than the 071 according spec that I have read unless someone knows better.
Hi Richard not sure if I need to go to specsavers but the battery in it was an 075 which is the correct fitment however the 096 is 15mm taller that's why I need a longer strap, my apologies for the confusion
   Bill
