Mondeo MK3 ST washer bottle
I'm trying to remove the windscreen washer bottle, I've moved the wheelarch liner taken the under tray out removed the 2 bolts which are visible, it still wont come down so there must be a third fixing, I cant see a third fixing does anyone know if you have to remove the bumper this seems a bit drastic.
Hoping you can help.
2 screws either side and 1 on top near the fill neck.
That was my problem I couldn't see the third fixing, I guessed there are three, How do you get at the third fixing, do you have to remove the bumper,
According to Mr Haynes, there are 2 front mounting bolts and one rear. It says for better access it may be necessary to remove the bumper
Thanks, it seems a bit drastic for one bolt, many thanks.
Not a wet Saturday job!
