Mondeo mk4 2.0 tdci
Hello guys
I just bought a 62 plate estate and it doesn't have fog lights on the front.
Does ford have the plugs behind the covers?
I know manufacturers just use the same loom for their cars and hide the plugs that aren't used is that the case with the mondeo?
Anyone with any idea?
Just have a look yourself, removing the covers look for a plug.  Or even check your fuse box, you might have the fuses fitted already and would just need the lights and switch fitted and programmed.
But why even bother, fog lights don't serve any function really front ones are usually over powered by headlights.  So many people don't even know how use them correctly either 🤷🏼‍♀️
Fog lights used to be only used with sidelights the idea being they shine under the fog.
as to the op some do have the wiring for extras and some don't fog lights are often on an extension loom so you may find a multi connector which would take an extension not allways where you would think either
Thanks I will do that.
Can forscan programme the lights in etc?
Thanks 👍
