Clutch's and Gear Oil Seal
I recently bought a Mondeo 2013 Trend (Gear 6dct450)
It has a small leak in the oil seal
And the clutch only slips on a morning ride. after a minute or so of shifting gears
It moves smoothly without any problems
I heared that if you repair the oil seal the problem can return and it is recommended to rebuild the gear???
Which oil seal are you talking about.
https://www.automaticchoice.com/en-us/getrag-6dct450-powershift-dual-clutch-transmission-parts-catalogue
What is the veh mileage - Trans oil and filter MUST be replaced every 37,500 miles or 3 years, whichever soonest.
IF/when the trans oil level is correct does the trans still slip - if so, you have a problem
A specialist (if you can find one that's any good!) will probably charge around £2,000 upwards to do a rebuild. An exchange Ford trans is around £4,500 fitted
Is this any easier to identify which seal you mean
https://ford.7zap.com/en/car/180/7.1796/70/1919/16946/
Thanks for the response. But I have no information about the damaged part. the garage just said there is a drop of oil. that's it for now i'll check it more seriously next time
