2015 Mondeo - Quick Clear Fuse Access
With the recent freezing weather, having tried to use the quick clear screen, it looks as if it is not working.
I have seen several articles that suggest it may be one or both of the two fuses that are located in the lower tray of the Powertrain fuse box in the engine bay.
I'm struggling to gain access, as the instructions in the ford manual seem to be less than useful!! I managed to get the cover off by unclipping the tabs marked A on the photo (albeit one snapped off when I was doing it!!). However, I can't work out from the manual where the two latches are to release the top tray. On my vehicle, I have found a latch at location C, and there is a different type of latch as location B, but neither of these seem to release the upper tray.
Would be extremely grateful if someone could advise in simple terms how to remove the top tray!!
Many, many thanks.
To be honest it's more likely to be your battery on a 2015.
Is your stop start working as it should?
