Help. At a loss
Hi all, I own a 2010 X Sport with 59k on the clock. Last year the eml started flashing, then loads of white smoke and misfiring. Managed to get home just.
Plugged it in and came up misfire in cylinder 3. So I ordered 4 coil packs from Ford and changed them all.
Everything was fine till last week when the same thing happened. So I unplugged them one by one and came up misfire in cylinder 3.
Right. Reset the eml and code. Started the car again and it said multiple random misfire.
I ordered 4 connectors for the coil packs and rewired them. It's still the same. Now I'm thinking injectors.
Any help would be appreciated.
Number 3 plug is wet and the other 3 are sooty.
I've changed all the plugs and makes no difference
Vince, is it petrol, if so you need to do a compression check as they are known to have a major piston failure problem
Hi Trevor, yes mate it's 2.0 Ecoboost. Not looking good then. It's not burning oil, just a strong smell of fuel and the plug is we with petrol not oil.
Would have thought the plug that's wet would be wet with oil if it's a piston problem? Not sure though not a mechanic really.
Got it towed to the local garage.. will keep you posted.
Thanks for the reply
Edited by Shadow1066
Add some more text
Him Vince, sorry, stupid me. I should not have had to ask if it was a petrol engine.
That will be really great news if the spark plug is wet with petrol
Here are a couple of links that are available that give you info re the piston problem. Its worth doing a compression test whilst the spark plugs are out
https://talkford.com/community/topic/231020-20ecoboost-240hp-engine-failure/?hl= piston failure
https://talkford.com/community/topic/387163-20l-ecoboost-engine-fubar/?hl=%2Becoboost+%2Bpiston
Hi Trevor,
Thanks for the reply. I will get the garage to do a compression test whilst they have it. They rang today telling me there's fuel coming out the exhaust. I'm leaning towards a fuel injector being stuck open, therefore over fueling. There going to check all injectors and renew all 4. Told em to stick some new plugs in and check all coil packs.
Did notice that when sat in drivers seat and press the start button, (without starting engine). There's a clicking maybe half a dozen times under the passenger side dashboard. Then it stops. I've never noticed it before, not sure if it's related of not
