ignition barrel
having abit probs with my ignition barrel some times i got to jiggle the key to start car,,so how to i go about adding a new barrel would i need keys prog or if barrel comes with one will that be ok
Buying a new key will probably give a tighter fit and less hassle 👍
You'd think so, however when I 1st got my 2005 car, wanted a 'spare', and the cheapest quote I got for a fully programmed key was £240! (Needless to say, I don't have a spare!)
Less hassle sometimes equals expensive 👍
i got 2 keys and both do the same lol seen a few 2nd hand ones on ebay with key so would i need to prog the key still i can use my old key fob for locks its the the ignition side of it
A new key will have to be programmed.I think an auto locksmith will cost about £60👍
  • 5 months later...
I will definitely buy a new key from an auto locksmith store near me.
Wow, no wonder it took you 6 months to reply to this, all the way from Texas LOL Guess you work in the locksmith then and looking for business 🤣
Sometimes when the steering is locked it can do that but instead of jiggling the key move the steering wheel and that usually frees it up.
If your keys are the type where the key blade can be separated from the button part then if you swap the key blades over and use your original button part then no reprogramming required when you change barrel
An ignition key barrel can easily be replaced. A standard key barrel is available from Ford. The new standard key barrel can easily be converted to the correct key code using locking plates that are also available.
  • 3 weeks later...
cheers lads but i sold car on now,,iam a vw touran lol
I believe those are nice economical vehicles, plenty of MPG LOL 🤣
ha ha its a 1.9 tdci stuck 20quid in when warning light came one then when it flashed back up trip said 158 miles that was just around doors just had it mapped few days back so might get a few miles from it lol
Good luck finding the 'C' in a 1.9 TDI. :biggrin:
lol i no that now
