Loss of power
2017 Fiesta 1.25   manual
When I have been driving I have experienced a loss of power (like I'm in the wrong gear) so I drop a gear and accelerate to pick up the loss of speed to find the car holds back and loses power again,  problem occurred 4 times tonight whilst on short trips,  yesterday I went for a long drive (roughly 120 miles ) and no problem occurred.
The loss of power has been intermittent over a few weeks but more so today.
Any ideas?
Fuel pump?
Throttle body sensor?
Edited by Rachel8889
2 minutes ago, Rachel8889 said:
2017 Fiesta 1.25
Any ideas?
Fuel pump?
is it a manual or auto?
Manual
when you loose power is the car gaining revs despite the loss of speed?
To be honest  I don't really notice,  i kind of panic ... as i don't want the car to stall .  The only way to describe it , is like when your driving up a steep hill and you begin to lose power so you drop down a gear to gain power.
If it was gaining revs as the car lost power i would say clutch related, however what your describing sounds more like either a fuel problem or the intake being overly restricted (most likely from a clogged air filter)
My thoughts exactly,  but wasn't too sure.  I will get the other half to change the air filter asap , hopefully it's a small issue 😬😬
Thank you
I'd guess your MAF sensor is playing up, but it's hard to say without some live data. Could be anything from plugs/leads to an o2 sensor.
Quick update
Partner drove my car today and the loss of power still present,  and then the message 'engine service ' popped up on the stereo along with the spanner,  he clicked ok and the message/spanner went away.... ge said it has been fine since .
When was it last serviced?
He did a part service 6 months ago and I have done 8000 miles since .
Had new spark plugs , oil drained and new put in and he changed the air filter .
  • 3 years later...
I had this exact same problem and no one ever posts how they fixed it so I am now. The vacuum pump valve tends to fall apart inside, so the fix for it is to replace that with a genuine ford part. I temporarily fixed it at the moment by putting it back together and supergluing the end on making sure I didn’t glue the orange diaphragm😅 If this doesn’t work then it is probably a boost leak (air escaping) from the intake pipes. Hope this helps
