Power Issues
Hi guys, after some help / recommendations.
My car a couple of weeks flashed up with an engine service now message, traction control light and limp mode. I took it to Ford under the warranty and they replaced the EGR Valve. I get almost home and I got the traction control light on and in to limp mode. The dealership took it back in the following day but couldn't find a fault. After various issues with Ford I'm not taking it back there.
It's been suggested it is a turbo issue or control module but I'm not sure. Has anyone else experienced this?
I can tell when it is going to happen as my exhaust gets louder and then the light/limp mode happens. It seems like it only happens if I drive the car above 2500 revs or when I've been driving a while and stop at a roundabout/junction as soon as I pull away it goes in to limp mode again.
Help :)
I am having simular fault
 limp mode ,ABS, Traction control.
RAC called out cleared fault then followed me home .
Fault reappeared after driving 15 miles at 50 mph+.Fault cleared again.
Drove 100 yds fault lights on again .
Free wheeling so I turned ignition OFF ON RESTARTED ENGINE   .
Driven 80 miles since without fault re accuring.
Unless you get a specific fault code we can't really help. Just saying you have an engine management light and limp mode means it could be anything.
I realise that without code it isn't a very good  post .
But how come turning ignition off / on then starting engine
Seams to have sorted the problem.
I have now driven 120 miles without ABS /TC or limp mode
Re accuring.
It depends how intermittent the fault is or what's causing it in the first place.
My late wife had the focus 7 years .
Less than 1k per year for 4 years. Hospital and shopping trips.
Now done 69k .
All I changed in that time was both snapped front coil springs  and noisey rear hubs .
As lockdown eased I  decided to have a go at clay pidgeon shooting.
Access was across a grass field it was a bit rutted but drivable. Thought I  may have disturbed an ABS sencer through extra front strut movement.
RAC CALLED OUT due to abs,tc limp mode .
When he put scanner on he said very Few  DTC recorded.
When limp mode came on again on way home he scanned again .
There was a lot of info on the screen that didn't make sence.
He said it could be the ECU failing .
I looked over his shoulder and saw some of the display as he flicked though the faults .
I did read bits about lost electrical connections
I asked him for a copy of the DTC Read out which he said he would e mail me.
HE DID NOT E MAIL THEM TO ME. So I  cannot act on or  give fault codes.
Also saying the info would be left on ECU for garage to read.
He cleared faults I  drove 100yds then it went into limp mode again showing abs and tc warning lights.
While free wheeling I turned ignition OFF ,ON ,STARTED ENGINE.
ALL FAULTS AND LIMP MODE CLEARED .
Since driven 145 MILES .
Without any faults.
Also reading about water ingress into wiring harness from screen washer pump or blocked window screen drains.
I had washed screen before parking up at shoot while car was facing up steapish hill.
So may have had water ingress causing a shorting out issue to ECU.
No further problems.
I have now driven 470 miles without any fault s being put on dash .
It may have been water ingress into the passenger side.
Causing intermittent shorting od BCM.
I washed windowscreen while car was parked forward facing on a steep hill possibly causing the issue .
Driven through very very heavy rain today without a problem.
  • 3 months later...
Up date now driven 12miles with out this problem  re appertaining.
