DTC 1261
Focus1 6 tdci 2011 70k
Driving from cold engine rough running then about a mile down the road limp mode and error message service required.
Connected scanner fault found dtc 1261 no 1 injector hi to low dead short.
Cleared dtc drove perfect.
A few days later same thing happened .
Cleared again and checked harness and no1 injector connection it was clean and shiny so put back together  .
I have left the rubber covering off for now .
What's it for?
What to do next?
  • 3 weeks later...
This went on to become a breakdown  and recovery.
No 1 injector  failed with a dead short across a the hi and low  solenoids .
RAC also diagnosed  p1261 injector  fault .
If it had been p 1264 it would have been no 4 injector.
I purchased a s/h injector of the correct code numbers printed on top of failed injector .
Cost £110 delivered DHL this morning.
Had the tip soaking in brake cleaner for a few hours with the rest of injector resting against a box. Cover pipe out let's to keep dust out .
I  CLEANED AND ANNEALED THE COPPER WASHER THEN RE USED IT.
Fitted this afternoon all went well .
DO NOT RE PROGRAM.
started a little rough but soon expelled the bit of trapped air .
Smoothed to a good tick over .
Still had engine  fault on dash but not in limp mode
Connected scanner cleared DTC P 1261 .
ADDED " CLEAN DRIVE"  FUEL INJECTION  CLEANER TO 1/4 TANK OF FUEL . COST £20
DROVE 45 MILES CAN TELL DIFFERENCE ALREADY .
MORE RESPONSIVE.
WILL COMMENT MORE WHEN I HAVE USED THE REST OF THE  1/4 TANK .
IT SAYS TO DRIVE TILL LOW FUEL WARNING  COMES ON THEN RE FUEL.
