Focus St 2007 clutch replacement
Hey
i am going to replace the clutch on my 07 ST with a 3 piece RS kit, it’s starts to slip abit when I up the power, my question is if anyone has an answer would I need to replace the fly wheel aswell or is the original one ok?
thanks in advance
Yeah, the standard clutch is 💩 in the ST.
The RS clutch kit will fit onto the ST DMF, but whilst the box is out I'd recommend changing it for peace of mind.
You can also fit an s60 clutch and flywheel. I believe these are a solid flywheel, so a little bit cheaper.
Cheers luke
