Evening all
Evening people
I have joined mainly to help out my son. He has ADHD so doesn't do many online forums. I have bought him a 2010 Focus for his 1st car. There are a few niggles I'd like to get sorted for him.
The stereo is the Ford Sony one. There is a BT module above the glovebox. A USB/Aux (which don't seem to work) & 12V socket which is powered in the centre console.
Radio works fine on DAB etc but when you hit the PHONE button all it does is MUTE the sound.
Anybody come across this before.
Cheers
Matt
The same question was asked about the mk4 mondeo (which uses the same stereo).
Basically my answer was the Bluetooth module is so old it doesn't support music streaming. However, it appears your module looks new enough to support it (I think).
If the aux/usb isn't working then I suspect you have a faulty bluetooth module as that's where they are fed to. Try unplugging it, leaving it for 30 mins, plugging it back in and try to use it again.
8 minutes ago, Matt1010 said:
Evening people
Cheers
Matt
Hi Matt,
Welcome to fordownersclub.com, I'm Lenny I've been on here since 2010 and have gathered a lot of knowledge over the years as well as owning a 2010 Ford focus myself,
what spec is the focus? for example "style" "Zetec" "Zetec-S" will help us to know weather that Sony head unit was a factory fit,
there's a good chance that a previous owner fitted that Sony to upgrade the standard 6000CD unaware that the Bluetooth module is synchronised to that specific head unit by ford, so although physically connected the head unit wont communicate with it until its told to, much like installing a new piece of hardware on your desktop computer or laptop it needs a driver update to function.
all said then; if you do get it functioning which will cost you a trip to ford to be fair; the Bluetooth of 2010 doesn't support music streaming, it only allows basic voice control and phone calls, it wont ever stream music through the head unit,
personally I've gone for an aftermarket head unit, and removed the 12v socket from inside the arm rest; fitted a replacement 12v socket sized USB port and HDMI input socket interface which are connected in to the rear of the aftermarket head unit,
plug in a NowTV stick or Amazon Fire, use your mobile phone as a wifi hotspot.
hope this was of some help also here's my list of guides all done on a 2010 focus mk2.5:
Guide to Fitting Genuine focus Mk2.5 ZetecS rear Diffuser Click Here
Guide to Fitting Genuine focus Mk2.5 ZetecS Front Lip spoiler Click Here
Full ZetecS Kit Fitted to Mk2.5 Focus Click Here
Custom Laser Cut Interior Parts For Your Ford Click Here
Guide To Storing Vehicle For Long Periods Click Here
Guide To Activating Single & Multi Door Unlock on yor Ford Click Here
Guide To Spraying Rear View Mirror Click Here
Guide To Changing Lower Front Grill On Mk2.5 Focus Click Here
Guide to Fitting Custom Built Climate Controls on Focus Click Here
Guide to Fitting New Ford Mist Type Jets on all Models Click Here
Guide to Wiper Blade Change Focus Mk2 Mk2.5 Click Here
Guide To De-Wiper Rear Of Focus Mk2 & Mk2.5 Click Here
Guide To Fitting Boot Door Umbrella Holder Focus Mk2 & Mk2.5 Click Here
Guide Tow Strap style boot handle Ford Focus Mk2 & Mk2.5 Click Here
The Ultimate Rear Seat Protection Click Here
Guide to Fitting additional Boot Light Click Here
Guide to Fitting additional 12v Socket in Boot of Focus Click Here
Guide to Converting Rear Fog Light To Clear Click Here
Guide Fitting Mud Flaps to ST, RS & ZetecS FocusClick Here
The Ultimate Reverse Bulb Click Here
Guide To Fitting Second Reverse Light Ford Focus Mk2.5 Click Here
Guide To Fitting ST Gauge Pod To Focus Dash Click Here
Guide to Fitting Auto Dimmer Unit to Gauges or DRL's Click Here
Guide Restoration & Fitting Focus ST Recaro Seats in to Mk2 & Mk2.5 Focus Click Here
Guide to Fitting Footwell Lighting In Your Ford Click Here
Guide to Induction Filter Upgrade in Your Ford Click Here
Guide to Fitting Custom Bonnet Dampers Focus Mk2 & Mk2.5 Click Here
Guide to fitting Ford puddle lights Focus 05-12 Click Here
Guide to Fitting Genuine focus RS LED tail lights Mk2.5 Click Here
Guide to Fitting Aftermarket headunit focus Mk2 & Mk2.5 Click Here
Guide To fitting 10" HD Flip Down Monitor Focus Mk2 & Mk2.5 Click Here
Custom 10" Sub enclosure & Amp panel Focus Mk2 & Mk2.5Click Here
Guide Installing Reverse Camera Focus Mk2.5 2008 - 2011Click Here
Guide Fitting Dual Camera DVR System Focus Mk2 & Mk2.5Click Here
Thanks chaps. I'm not too bothered about the streaming to be fair. Just to get the BT working would be great so he could contact us easily or answer a call if needed.
Len It is a 2010 Titanium 1.6 Auto. All the toys, heated seats, DAB,keyless etc
I will try the disconnect and reboot method. I have a Double Din Kenwood in the garage that I had in my X-Trail that I scrapped so if it going to start costing money I think throwing that in it would be a better option. It has DAB,Sat Nav, BT etc so he wouldn't lose out even though it is a few years old.
Thanks again
