Wynns formula gold diesel treatment
Hi all I'm after a bit of advice pls. I have a 2008 1.6 TCDI Ford Focus and each time I put Wynns formula gold diesel treatment in it pours out from behind my rear wheel arch. Why is this happening as I push the spout all the way into my filler.
I would guess that your spout is too short and it is pouring out the breather pipe. Buy a plastic fuel can put some diesel in it and try then putting that in the car. If it goes in without a problem which I expect that it will, then all you need to do is add the diesel treatment to the diesel in the can and pour it in.
Does 2008 focus have the easy fuel filler with no cap? If so you need the proper Ford plastic funnel to open the flap further down
