Passengers lower than drivers side
I lowered my car on Whitelines 25mm springs and the passengers side is lower than drivers side. inspecting the suspension i came across a split in the coil seat on the lower side. Could this be the cause? I also reseated the passenger's side but no change.
I had new Ford Antisqueak mounts fitted to my 2016 ST, when I had the Eibachs fitted. 2 x front lower mounts, 2 x rear upper mounts and 2 x rear lower mounts, were less than £30.
Where did you get them from?
